Fuse #17 START - STOP - radio / Daylight driving lights
Hey everyone!
I have just hardwired my dashcam with a piggyback fuse on my 2012 Fabia II 1.2TDi Combi. I tried initially the fuse #17, START - STOP - radio / Daylight driving lights, as I have seen it recommended by many others before. When I connected the cam to it, current stopped coming to the fuse for whatever reason (the fuse is not blown). I disconnected the fuse and tried to see if current is coming through to the terminals and it reads zero as well. Before I was getting 12v readings. I piggybacked fuse #26 then, rear window wiper, and it worked fine with no issues. I am just wondering what could have happened by connecting a piggyback fuse to a fuse slot to make it stop drawing current/voltage. And what would you recommend to diagnose the issue? Radio works fine, did not check the DRL yet though.
Any ideas?
Kind Regards
Daniel
Edited by DanielFenech
UPDATE: DRL were not working. Checked the switch (located by the fuses) and they were indeed off. I must have hit the switch with the piggyback fuse when I was putting it in :)  Way to make myself look like a genius. Turned the switch back on and now the fuse has current going through it. So problem solved. Still find it strange that a switch determines current to the fuse, not vice versa :)  Leaving this here just in case someone else tries to find why fuse #17 (specifically for the daytime running lights) has no current/voltage - check the switch!!
