Temperature gauge - fuel level gauge - clock not working
Bonjour everybody!
I bought a Skoda Felicia Pickup 1.9d last year.
Have had a few problems, but fixing them.
But one problem remains, and I have found no answer on the Briskoda forums :
- temperature gauge does not work (set to zero and doesn't move at all)
- fuel gauge isn't working either - sometimes it work, not for long, but I don't think it indicates the right level
- clock isn't working either. But the time changes, so it must be working sometimes.
Maybe an electrical problem? false contact somewhere?
Thanks for the answer, and thanks to Briskoda!
A bientôt!
Thanks for the answer! Merci!
Do I have to pull out the dashboard?
First what you can see from outside (engine bay, fuel pump connections etc) and IF everything fail you have to remove the dashboard.
Check each gauge individually, i will try when i get home some electrical diagrams.
Check also the fuse box, sometimes dust-corrosion-not proper contact create problems.
Contact cleaner (the No Oil edition), light brush is a solition.
Thanks a lot
i’ll try and let you know
Dash is not getting power check for cold solder joints on the main harness connectors
Cheers! I'll check that too!
