Skoda Fabia II issues
I've had my Skoda Fabia II Greenline 1.2 for a few years now and I've noticed over the last 6 months slowly each electric part is going one by one, started with the drivers electric window, it started to be faulty only working sometimes then eventually completely went as well as the control for the passenger side on the drivers side and the leds in the lights. Not long after the buttons for the passengers stop working on the passengers side as well as the Leds, then a couple months later the led for the central locking in the center console in-between the seats (under the Dash) went feels like a waiting game to see what goes next.
( I've had the wires on the door card checked and I've had the fuses under the dash checked but no issues there). The only thing I could think that maybe it's a battery issue but I've no idea what to try, any help would be appreciated
You say you have checked the wiring in the door, but have you checked the wiring to the plugs on the A-pillar? That sounds like classic Fabia issue.
Open the front door remove the door open restrictor open door right up and then you can get at the pillar plug, realease the rubber seal and then realease the catch pull the plug out clean it with WD40 then apply a good layer of petrolium grease to the plug and reciever attch plug back in and re fit rubber seal if seal gets broken you cabn get them or at a last resort you can use part of a rubber glove that usually sorts out lots of issues
Fault is more likely to be caused by fractured wiring in the door loop than poor connections.
Sounds 100% like that.
Thanks for your help everyone I'll have a little fiddle with it all on my day off, the only thing is though do you think the Electric going in the window buttons has any conection with the central locking button randomly not working or illuminating any more in the same sort of way in the center console or the passenger buttons doing the same?
It could all be connected (or disconnected more like 🙂 ).
Edited by Jocko
100%
Drivers side door control module receives inputs from all of these and has outputs controlling the door locks, electric windows, door mirrors, fuel filler flap etc.
Usual fault is fractured wires in the door (hinge) loop.
