All-wheel drive Sport option ?
Hi All,
I watched a video reviewing the new skoda superb and found out it had options for the all -wheel drive
Does anyone know what that does ?
I asked the Skoda customer support yesterday the same thing. I am waiting for an answer.
It will matter which countries it is being sold / bought in will it not?
Guys, no news here? I'm eagerly looking for that piece of info. Did the customer support replied something to you?
Sorry no. And I have forgotten to ask again.
AI: In the fourth-generation Škoda Superb (2024+), setting the 4x4 drive to Sport mode within the Individual settings primarily changes the torque distribution logic and the system's "eagerness."
Here is a breakdown of what happens technically:
1. Proactive Torque Distribution
In Normal mode, the 4x4 system (using the 6th generation all-wheel-drive coupling) is reactive, meaning it waits for a hint of front-wheel slip before sending significant power to the rear.
In Sport mode, the system becomes proactive. It sends more torque to the rear wheels immediately during takeoff or when accelerating out of a corner, even before any slip occurs.
2. Rear-Axle Bias
While the Superb remains a front-biased car, the Sport setting increases the clamping force on the AWD coupling more frequently.
The Result: The car feels more stable through corners, provides better "push" out of turns, and significantly reduces understeer (the sensation of the front end pushing wide).
3. Faster Response Times
The control unit communicates with sensors (steering angle, lateral G-force, throttle position) at a higher frequency. The system is essentially "primed" to react to changes in grip instantly.
4. Synergy with ESC
When you set the 4x4 to Sport, it works best in tandem with the ESC Sport setting. This combination allows for a tiny bit of wheel slip, which, combined with the active rear axle, allows for much more dynamic handling, especially on wet or snowly surfaces.
