Skipping card reader
My sd card with music on it keeps 'skipping' jumping while playing. It's an expensive sd card on which I've cleaned the contacts. Does anyone know of a way to clean the reader?
Any help on this topic?
Hope he doesn't mine me tagging him but @Breezy_Pete may have an idea?
11 minutes ago, Squyre said:
Hope the info helps you sort it out
is it an expensive card in a cheap reader? Might be using an old format USB which won't go fast enough or is causing an issue with the card.
