Kill Switch in a Skoda Felicia
3 hours ago, D.FYLAKTOS said:
The reason that i choose this model was this:
Intelligent Automatic Disconnection: The car remote battery cut off switch features an automatic disconnection function that activates if the battery voltage drops below 11.8V.
On a starter motor solenoid, what could possibly go wrong! 😁
"if the battery voltage drops below 11.8V"
Does your car starts with the battery at 11.8 Volt?
I think if the switch is connected and the battery drops at 11.8V then disconects automaticaly, where is the problem?
Yes and even with it fully charged at 13.3 volts it would drop below 11 volts when cranking.
You will not be able to start the car - see above.
At 11 volts stand-by (and cranking will drop it more) mine does not starts.
