Heater only warm on footwell
Hi there
New to this group and also octavia ownership
I have a mk2 2007 with only 30k on the clock. 1.9deisel
Based in UK sw
Before I bought the car I test drove and tested the heater and it was fine
Before the garage sold it to me they replaced the air con condenser unit
I've had the car a few weeks but only in last few days tried the heater
It's cold unless I turn it to thw footwell
It's a manual heater control. Nothing fancy just the manual dials for temp and directions selection
Footwell isn't that warm either tbh but better than all other options
Any thoughts much appreciated
Could this be related to thw Aircon condenser replacement?
I'm not sure how the heating and Aircon are related wet plumbing but wondered about an airlock ?
Many thanks in advance
Does the temp gauge read 90C ?
If an airlock, then you can check by seeing if both pipes to the heater matrix are hot. You can see the pipes going through the bulkhead around the centre of the car. The two pipes are the only ones close together.
Diesels take longer to warm up the coolant than petrol cars.
