Air Quality Sensor MK II Facelift Location
Hi Everyone,
VCDS gives me the following error.
Address 08: Auto HVAC (J255)       Labels:| 5K0-907-044.clb
   Part No SW: 3T0 907 044 AS    HW: 3T0 907 044 AS
   Component: Climatronic   H15 0401
   Revision: 00005001
   Coding: 0000000002
   Shop #: WSC 73430 790 00999
   ASAM Dataset: EV_Climatronic A01006
   ROD: EV_ClimaAutoBasis_SK35.rod
   VCID: 035398B01B99C9B24A1-8056
1 Fault Found:
9481988 - Air Quality Sensor
          B10AF 04 [00001000] - Internal System Fault
          Intermittent - Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 23
                    Reset counter: 115
                    Mileage: 70181 km
                    Date: 2024.06.14
                    Time: 19:13:05
The recommend fix is to replace the air quality sensor.
I thought the sensor was under the scuttle panel but I can't find it. I have read  this should be a 10 minute job but 2 hours later and I can't even find it.
Does anyone know where the air quality sensor is located on an Octavia MK2 Facelift vehicle.
Thanks.
Kev.
