Radio Aerial Adapter Advice
Hello
Need some direction just fitted a new android radio to replace my broken bolero radio. All has gone well however I need some advice to where I can get a compatible aerial adapter.
The Last picture is the current adapter that isn't compatible. The first image is the audio socket on the old radio.
I need an adapter with those sockets, can anyone help
Hi,
The middle image is Fakra dual male connector. Is this the existing connector in the car that you need to connect to?
Fakra connectors are colour coded, white male to white female etc. However the aqua green connector is an exception, it is universal and can connect to any other colour.
Try searching for Fakra adaptors to find the one you need.
Alternately, you could just buy the connectors and make up a custom cable.
Also, I should point out that it looks like the head unit takes a DIN connection, so dual Fakra to DIN is the connector you require.
Kev.
Thanks so much for that, my first time changing the head unit, much appreciated
