Warning lights
I have an intermittent set of warning lights coming up on my Octavia scout 2015. It has happened a few time where I will get the following all at the same time:
yellow ESC light
tyre pressure monitoring not available
park pilot not available
sometimes It will reset itself as I drive other times it will reset once I do my return journey after sitting a while.
Any help would be great
Sounds like an intermittent problem with a wheel speed sensor (or the wiring to it) to me - all those systems rely on accurate vehicle speed data.
Time to do a fault code scan (with VCDS, OBDeleven or similar) to get a clue which wheel to look at.
Hi, welcome.
As above - also check the state of charge of your car's battery preferably at the battery terminals when the car has been parked up and electrics unused as long ago as possible/practical, a battery in a lower state of charge can upset the car's computers even before any dash warning lights or messages and well, well before the engine has difficulty starting.  Plus colder, wetter, frost, snow, shorter days are on the way you want the battery in good condition and state of charge before these.
Edited by nta16
