airbag light
Have got an airbag warning light after drive belt failed. Is there any way to erase it. 2008 roomster
VCDS
An OBD2 SCANNER ABOUT £16 TO £20 should reset it.
To add more I was looking for a possible parasitic drain pulled out a fuse with engine running.
Air bag light stayed on no matter what I did but a cheap scanner cleared it and panic was over.
bobspark - any idea what scanner you used. Mine won't clear it but also shows no faults.
Car Code Reader,U281 OBD2 Code Reader DTC Scan Quick Diagnostic Reset Diagnostic Check Tool Replacement for Car Vehicle from AMAZON £23
Found it hard to insert into socket and hard to understand (maybe me)but it cleared the fault.
