After market tow bar
Hello 👋
I'm looking at getting a tow bar fitted to my 2024 vRs Octavia estate. I've had all sorts of different information from fitters and I just wanted to see if anybody here has had one fitted?? One of them said that it couldn't be coded, another said about needing a dealer trim etc.
Thanks!
13 hours ago, luizzah said:
Hello 👋
Thanks!
Hi
The first thing to look for is the towing limit, a lot of the Octavia's are rated at 0Kg so no chance of getting a bar fitted, but there should be no
reason why you cannot have one fitted and coded.
I have a 21 plate and have done just that bar fitted and coded by a company in Manchester
3 minutes ago, RADIOTWO said:
Hi
Yes mine is fine and I checked the VIN it's rated for 1600kg. Which company did you use please? I'm not far from Manchester. Thank you
I have sent you the details via PM and mines rated at 2000Kg's
