Error: workshop! Only leave vehicle in position P
I get this error in my car :
I've been told that in order to fix it I need to buy this part in the gear box .
link -  https://www.ebay.com/itm/405049434141?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=5BIFTQObR-m&sssrc=4429486&ssuid=lpe7mnnwtmo&var=&widget_ver=artemis&media=COPY
but as you can see the car indicates about a part in the steering wheel area .
please help on how to fix this 🙏
That’s the VIN - TMBAC7NE1H0141101
Edited by GodKu
@pab567
Edited by GodKu
THis is just indication, you need to connect diagnostics tool (VCDS, VCP< OBD Eleven, ODIS, VC Tool) and read error codes
Welcome to the forum.
Worth a search sometimes to see if the issue has other threads covering the same issue.
I have this same fault, can I ask if you were able to fix the fault with the linked part, if so how easy is the repair and if not what the fault was?
Thanks in advance
Edited by BadlyDrawnBadger
Thanks in advance
The OP hasn't visited since October '24, so you may not get a response.
As has been said, worth a search to see how successful others have been. I believe this is quite a common fault.
Thanks for responding. I'll see what I can find in forums
Its a non concern from what I've seen
Got this on the L+K myself
There is a fix kit you can apply
Its not a break thing, just an annoyance pretty sure ? As it doesn't cause any change of gear or anything.
My scan was     B116229 - Selector lever park position lock switch implausible signal
            Intermittent
Some nice Irish dude talks through the entire fix
https://www.youtube.com/watch?v=iwLVR5WvWfk
Thanks, I looked around other forums and found links to same part as OP so ordered part and fitted it couple days ago. So far this seems to have completely fixed it
Initially my car only came up fault very sporadically, maybe once in six months but last week it started coming up almost every 10-30 seconds so had gone beyond annoyance levels and I had concert to go to yesterday over two hours drive away so not sure my sanity would have survived journey if it hadn't worked
Thanks again for responding, I really appreciate you taking time to read and reply to my query 🤗
Its only very occasionally intermittently showing on this L+K so hardly a priority but great info sharing on the problem, I will go down this route with ordering + video if it becomes more glitchy.
