Engine cover removal.
Hi Members,
I have a 2003 1.2 HTP, does anyone know the correct engine cover removal procedure.
Kind regards.
Iain G.
  • Sponsor
6-valve 54bhp 1.2 HTP or 12-valve 64bhp 1.2 HTP?
For the 12-valve:
Two air hoses on the battery side of the cover to disconnect I think.
Rearmost one has a fitting that you squeeze opposite sides to release, frontmost one is just pull off.
Then it's just a matter of pulling upwards, quite hard.
I find it best the lift the rear edge first, hooking thumbs over the metalwork just behind, then pulling up hard with fingers.
Once it's off, a smear of silicone grease on the (4) rubber fittings that retain it will make it easier next time.
Dunno about the 6-valve version,  if it has a cover.
Edited by Breezy_Pete
6/12
It's the 12 valve triple, thanx for your help!
