Different size spare wheel
Will a 215.55 R17 wheel from my old Karoq fit the hub of my new one that's fitted with 215.60 R16, as a spare.
Yes, almost identical circumference.
Thank you. I was concerned about the bolt holes lining up correctly with the hub.
Ah, I see, yes they will be the same and therefore will be compatible / interchangeable.
Can’t say if it’ll fit in spare wheel well though.
Edited by Berisford
Hello, I've got little bit different question. Can i use spare wheel from Kamiq to Karoq or from Kodiaq to Karoq?
Mibbae aye, mibbae nay. It will depend on wheel (and tyre) sizes rather than just PCD though.
Welcome.
Kamiq have a PCD / stud pattern as a Fabia / Scala. 5 x 100.
Karoq & Kodiaq are 5 x 112.
Then we get to wheel size / width and tyre sizes.
5 hours ago, Ootohere said:
Welcome.
Ok , thank you, good to know.
