Stoplock Pro or Elite
Hi was just wondering what would be better fitting for the karoq the stoplock pro or the elite  ... Thank you Gary
I have the Pro version, and easy to fit and remove. I put it on with lock to bottom right of the steering wheel. Mind you, I bought it before finding the KESSY override trick, so it doesn’t get a lot of use.
I have the Stoplock Pro. It fits the Karoq steering wheel well and gives a little extra peace of mind.
Hi al thanks for all your replies yep the Stoplock fitted perfectly  👍
I have a Ghost installed. Before had disklok, still using it occasionally.
Are these locks really still needed?
The Karoq is far less of a target than other older cars or high value cars, where it is worth the risk.
This is what the stats show  (2018-24). The older hatches get stolen (fords, golfs etc) or the high value Range Rovers, Mercs etc.
Looking at the Confused.com theft risk calculator, there have only 50 Karoq thefts in the last 7 years! I would bet that is through someone boosting the key fob signal.
If the keys are kept in an RFID pouch, keyless entry is forestalled.  If they are going to steal the keys then they are going to steal the keys for the lock too
Or just wait for you to turn up at the car and unlock it, then take it.
