SKODA SUPERB 2016 TPMS FAULT
Hi iv got a skoda superb 2016 uk model and after a puncture iv had a nightmare with my tpms keeps going off and keeps showing a tpms sensor fault even after reset and tire pressure check is there any way to deactivate it or install new sensors and it's the one attached to the abs sensor aswell any help would be great thanks
Superbs don't have sensors in the wheels 😞
indirect TPMS system calculates from ABS
to avoid guessing what's wrong, i have installed dTPMS
alternative set, independent to car's system
-> https://www.briskoda.net/forums/topic/434028-tire-pressure-monitoring-system/?do=findComment&comment=4893182
there is info how to install OE set, integrated to car's system
-> https://www.briskoda.net/forums/topic/488740-my17-superb-retrofitted-with-direct-tpms/
Edited by MartiniB
As above, the Superb has Indirect TPMS, using the ABS sensors to detect each wheel's rotational speed, and hence if a tire pressure is off.
Did u fix the puncture or change the tyre or put a spare wheel on?
When u reset the TPMS, did u hear a boing sound?
If ur still getting TPMS warnings then something might b wrong with ur ABS sensor!
Keep getting the warning coming up and a new tyre was fitted
Iv tried looking at the post and clicked on the links they don't work might be because the links are no longer there
4 hours ago, MartiniB said:
i have installed similar sets to this
https://www.aliexpress.com/item/1005006861769432.html
separate sets for summer and winter wheels
How do I install these just put them in the valve and also what or how do I deactivate the current indirect system?
I've had the same after having to change one tyre while the rest are part worn.
Keep doing the resets, eventually it will sort itself out.
@Nab93 - it's not a simple process to disable the TPMS.
There r a number of different modules u need to make code changes via VCDS or OBDEleven.
If I were u, I would b getting to my the root of ur problems.  Something is causing ur TPMS to trigger.
Have u scanned ur car for errors?
R ur ABS sensors good.
Which tyre is the TPMS sensor complaining about?  Usually it tells u which corner, like this....
Edited by JR RS
I have scanned it with a few different scanners and when the light goes off no error but normally the error alternates with all the tyres
Still have problems with these damn tpms might change all 4 tyres to a single company and thread and see if that work
4 perfectly matching tyres, or even all 4 or 2 pairs at matching pressures are not required to not get warning with the TPMS when not faulty and resetting OK.
Yh i keep getting error even though the pressures are okay
So first things that need checking:
Have tyre sizes been checked to see if all 4 are exactly the same
Have tyre pressures been checked and exactly what they should be - front and rear may be different
Has the system then been reset through the dashboard and then the vehicle driven
Have any fault codes been checked to see if they are stored
If at this point you are still getting faults, we then need to start thinking of a possible wheel speed sensor or wheel bearing fault.
How long after the reset does the light come back on - in terms of mileage and time.
Then when you know it is not faulty there can be an odd sized Spare Wheel fitted at a totally different pressure, maybe even  narrow SPACE SAVER at 60 PSI and the TPMS reset and no warnings.
Or there can be different circumference tyres front and rear and no TMPS warning.  Or a new pair and an old pair on and still no TPMS warnings.
All the tyres are same size and pressure iv had a puncture today but it didn't throw up any loss of pressure just had that sorted will drive and see if it throws anything up I have reset the tpms in the multimedia aswell let's hope it's okay now
No fault codes
