Transmission to engine bolts?
Hey,
Currently in the middle of a flywheel job and want to get new transmission to engine bolts, however I can’t find them anywhere online.
Does anyone know where I can source a set?
For Mk1 VRs, asz engine code.
Edited by allybtc
  • Sponsor
TPS, dealership, LLL parts (probably too slow) or an ebay seller called "VAGbolts" are probably your best options. If you literally just mean the ones that connect bellhousing to engine, I wouldn't bother replacing, just re-use. More important to consider replacing the vertical gearbox mounting bolts I'd suggest.
Also, super-important to be aware that the rear dogbone mount bolt is 61mm long, compared to a few of the other bolts of same thread that are 65mm long.  If you mix them all up and put a 65mm one back in there by mistake, you're going to bugger up your steering rack.
Big thanks for the bolt size tip mate, first time doing anything like this and probably would have ended up doing something of the sort haha
