interior middle light no illumination when opening door
2014 spaceback
dashboard icons signals which door is open
both end reading lights work and the middle light works if manually using slider
is there a microswitch located somewhere in the door? same as 2007 fabia?
or could this be controlled via VCDS
tia
Edited by Skodacrazy
Taking the light down has nearly fixed this issue with the slider switch
all works however doesn’t turn off after entering and starting car
