Issue with driver side mirror tilting all the way down when opening driver side door
Hello,
I'm experiencing a strange issue with my driver side mirror, in where it sometimes tilts all the way down when opening the driver side door.
It is not consistent, but occurs across different keys and driver profiles, even guest profile.
The dealership has not heard about this issue, and it of course does not occur when I have them check it out.
Has any one else encountered this issue?
Hi,
2 questions: How old is your Kodiaq? and has the battery ever been replaced?
It's a 2018 model, and the battery have never been replaced.
The battery may need replaced then. Have someone do a deep load test on it, and expect that to be free subject to you buying any required replacement from them.
Could be. Going to try to charge it up over the weekend to see if that alleviates the issue, if not, I'll have someone do a deep load test on it.
A friend of mine had some odd behavior with side mirrors with a MY18 Superb Mk3. For instance, passenger mirror was moving up/down while joystick was being pushed down/up. It even moved the passenger mirror when trying to set the driver mirror.
Once the battery had been replaced everything came back to normal... ;)
