Dsg 2021 Eco
Hello
Why on superb when driving, and when not pushing the throtle, gearbox throw out of gear and on  cluster says eco?
Can i disable this somewher?
'Coasting' mode.
Really you need to say what age your car is and what engine so what DSG it has.
Is it a 1.5 TSI ACT with a DQ200 7 speed twin dry clutch DSG, or a 1.6 TDI,  or a 2.0 TDI or TSI with a wet clutch DSG?
Hello, I assume that you have DSG gearbox - the feature you ask about is almost certainly 'Coasting'
 Dq381 7 superb 2021
What is coasting?  Where to disable this?
This is perhaps not good for gearbox?
What engine has the car and what year is it.    EDIT,  Sorry i see 2021.
Coasting is when the Car puts the DSG so that it is not in gear and to put it back in you touch the accelerator or brake pedal.  The car is freewheeling.
Happens when no load on the engine.
'Eco' can be different with a ACT engine and cylinder deactivation.
Edited by Ootohere
Its 2021 2.0 147 superb.
It seems simplest way to disable Coasting Mode is by selecting Sport Mode - seems to be that to permanently disable requires accessing the vehicles software via VCDS (or similar) device.
