Fabia Mk3 LED lights H7
Hello all!
This is my first post in this forum.
I made some search in the already existing topics, but not found similar threads.
I have a 2016 Škoda Fabia Mk3 (motor code: CJZC - EA211) which running with the original H7 dimmed halogen bulbs.
Unfortunately it has a very weak brightness.
Here in Hungary now it is legally to change the H7 halogen bulbs to LED bulbs, so I decided to change it, if possible.
I just checked the possibilities, but found on Osram compatibility catalog that my car is not listed.
Do somebody tried to repace the original bulbs with LED bulbs?
Is it possible?
Osram NIGHT BREAKER® LED Compatibility list
Thanks for your reply!
Do I need to use any ballast resistor, or additional adapter, or just simple we can connect the LED lights like the halogen ones?
Thanks in advance!
To determine if your vehicle model requires additional Philips CANbus Adapters, visit:-   Philips.com/LEDcompatibility-check.
With my Fabia Mk3 the 4 H7's are as good as the three cars below with them fitted, but I have changed the bulbs to Osram Nightbreaker's on my Fabia.
https://www.amazon.co.uk/gp/product/B07FXRDJV7
I also needed to raise the aim on the headlight bulbs a little under the bonnet using a 6 mm Hex tool each side.
With a VW UP, Skoda Citigo and a Fiat Panda it was just plug and play with the H4's needed.
Thanks. AG Falco
