Break lights staying on Skoda Fabia VRS
4 minutes ago, Breezy_Pete said:
Bad contact. Put a new one in, and maybe even try to clean the receptacles in the fusebox, somehow.
Yeah will get it sorted currently stuck in a storms path 😒 so will get back to when I can thanks you for your help
Sorry to bother you again but I found a fuse diagram online pretty sure it matches mine I’ve put in Skoda Fabia VRs mk2 automatic IMG_1723.thumb.jpeg.48a44ffb88cbe92a2212394e1d9aaaae.jpegand it’s given me this red one and in number 8 on the diagram it’s for breakpedal and coolant and I have no fuse in it ? Do you think this is the same
  • Sponsor
Stick a 5 Amp fuse in where that shows number 8, and see if all comes good?
Edit: (If you saw the previous version of this reply, please ignore it, I was being daft, rotating things wrongly in my head!)
Edited by Breezy_Pete
All good they are working as they should now thank you so much for your help !!!
  • Sponsor
Nice one, sorry for the initial bum steer on fuse location.
:D
:D
No no worries thanks for your help honestly and know I realised there was a 7.5 fuse in the reverse light one but that’s only for manual and I have auto and know the stabilisation light has gone off just the tmps know and I just checked all my tires there is one 215/40 17 and the other 3 are 205/40 17 so I’m going to get that one changed and see if that light goes off but again thank you so much for your help I’ve been trying everything for weeks !!
Breezy_pete I know this is the wrong thread but I have problem with my Škoda superb 2020 2.0 tdi my brake lights stay on whiles driving start stop not working along with adaptive cruise control not working and flashing glow plug light im getting codes p2535 ignition switch run start position short to plus any ideas?
  • Sponsor
Message me with the VIN or reg number please.
I would think the mismatched tyre sizes will be your problem there. The TPMS works off the ABS so any irregularities might well put the light on.
Yeah well after taking it out this morning the tpms light went off but I will be getting it changed to match the rest
Ah well, no immediate rush then.👍
