Skoda Felicia Steering wheel position adjustment
MHello, I removed the steering wheel of my Skoda Felicia vehicle, but when I installed it, the steering wheel looks crooked. What is the solution for this, how can I fix it?
Take the steering wheel off again and put it back on as straight as you can get it. That's it. The splines on the steering column and wheel are too coarse to achieve perfect adjustment.
Hello, thank you very much for your interest, but I attach it straight like this and then it becomes inclined again. Do I need to do it on a flat surface or do I need to turn it completely to the right or left? Okay, diayum.
Ok, put the front wheels straight, then put the steering wheel as straight as you can get it, noting that it might well not go perfectly straight.
If this is too hard, and any further communication beyond a "thank you" will be taken as meaning that it is, contact a garage with steering alignment equipment and a reputation for being able to use if.
