Torque limits
I have heard in the past that the gearbox in the RS has a torque limiter on it set to 280ish ft/lb, is this true?
Only yesterday I witnessed something quite incredible, 272bhp (at the wheels) and 325ft/lb running through a standard gearbox, engine and turbo.
Des
I didnt know it had a limiter, but a little bird told me it was only rated to around 270lb/ft.
After this things start going wrong :(
272hp at the wheels with standard turbo on a standard engine :confused:
Yes that is incredible.
I have heard in the past that the gearbox in the RS has a torque limiter on it set to 280ish ft/lb' date=' is this true?
Des[/quote']
std engine. g'box and turbo.... on a 20VT?
5spd 02J has lower torque rating then tripple shaft 02M 6spd
stunning figures... tell more...
Well - I don't know if this helps, but Mike @ Jabba told me that the Fabia TDI gearbox is officially rated at only 200 lb/ft torque, yet he says they easily cope with the 250 lb/ft the engines put out when remapped.
So, if the Fabia gearbox can easily take 25% more torque than officially it should, then I should think that if the Octy vRS gearbox is rated to 270 lb/ft, then a 25% increase would mean it should handle 340 lb/ft torque OK, assuming the same thresholds apply.
:confused: :D
(although how many have blown gearboxes putting out nearly 300 lb/ft?)
Well - I don't know if this helps' date=' but Mike @ Jabba told me that the Fabia TDI gearbox is officially rated at only 200 lb/ft torque, yet he says they easily cope with the 250 lb/ft the engines put out when remapped.
[/quote']
Thanks Jason, I did always wonder. Never had clutch slip etc on mine. :)
Anyone know what the figure is for the TDI 6 speeder gearbox?
I reckon it's around the 250lb/ft mark, as they're supposed to (unlike some) put out 230ish lb/ft as standard.
Yeah but what about the Fab vRS 6-cog one? - how will it cope with 320lb/ft+? :D
It will probably blow it, Colin. :D I wouldn't bother with Jabba. :p
I shall let you all know how mine holds out then! 310lb ft must be pushing it pretty close! :D
Me...
on an 02J 5spd.
2nd gear lost all its teeth.
323lbft torque 350bhp 1.8T
