Superb 3.6 engine management and Epc light, cranking
Hi, having a bit of a nightmare, car just stopped dead. When ignition is turned on fan is running with engine management light and epc illuminated and flashing also ESC fault shown.
when connected to diagnostic, getting 01166 Engine torque signal fault, 02391 Terminal 30 fault.
I have started at the fuse box and working back, would anyone have a wiring diagram showing the terminal 30 path. I’m not getting any voltage through the terminal L on the fuse box.
any help is greatly appreciated.
Spoiler
If you totally get stuck, try changing the crank position sensor. Notoriously fragile item on any car and will give those symptoms of perfectly fine car just stopping dead when running ok. If it cranks and cranks but doesn't catch then its highly likely.
I didn't have any fault codes though (Golf 5 GTi)!
Otherwise, check that the low pressure fuel pump under the rear bench is priming when you open the drivers door and you could try some easystart spray in the inlet to determine if the are sparks.
I drew a blank with those methods and all the fuses looked ok so I just went for the crank sensor as I got a QH one off ebay for £15 new old stock.
