Feeble horn
I love my inherited Fabia, however the horn is feeble at best. Where is it located and are there any recommendations for plug and play two-tone replacements?
My 2024 Fabia SE L DSG's horn is decidedly 'peepy' when heard from the driver's seat, but it is a lot louder when heard from outside the car.
There has been the occasional complaint relating to Fabia MK 3 horns (example here)
but (so far) you are the first to complain about Mk 4 horns.
Fabia Mk 3 horns were said to be located in the car's left front corner (which makes sense for a UK specification vehicle) so I'd expect the Mk 4 horn also to be there. If you lift your car's bonnet and get someone to sound the horn, it should not be difficult to detect (roughly) where the horn is.
There's an awful lot of 'stuff' in a Fabia Mk 4's engine compartment and (assuming my car's horn is where I expect it is!!) I was unable to spot it from above, nor from the front of the car. The Mk3's horn was said to be difficult to access and it's probable that reaching a Mk 4's horn in order to replace it would be even more challenging and require even more disassembly.
A BRISKODA forum member may be able to give you advice based on practical experience, or you could ask a technician at a friendly Skoda dealership what would be involved in replacing a Mk 4's horn.
Edited by DerekU
Yes, "peepy" is the word. I get the feeling when I use it, people look around and giggle rather than jump out of the way. I found a willing work colleague who peeped it while I was under the bonnet. It does seem to be around the radiator area. yes, thanks, I did see some of the Fabia 3 forum posts about replacement horns.
Would have to agree, the Fabia Mk4 horn sounds like a watery fart. Just another of the things I find so boring about the Fabia. Just never have felt any connection with the car, and have had dozens and dozens of cars over the past almost 50 years of driving. My Monte Carlo is due its second service in two months, only covered about 1300 miles. Not having a go at anyone who is enjoying their Fabia, just my experience is pretty boring. But, I do plan to keep it as I have only used it in dry weather, and never in winter, so basically brand new. Maybe one of my grandchildren will inherit it. Haha.
1970dazzler
If you are desperate to replace your Fabia's horn, you might try removing the front-left fog-light (I think all UK-specification 2022 Fabia Colour Edition models had fog-lights as standard) and see whether that would allow sufficient access. If not, you'd probably need to replace the front bumper.
Edited by DerekU
