Help Request: Sheffield-Based VCDS Needed To Clear Fault Codes
Hey loves! As title - my 2006 Octavia Mk2 VRS has some wonderful fault codes that need clearing (you can see more in my previous post). I'd message someone on the map myself, but I'm restricted from doing so since I don't have 20+ content items!
If anyone would be kind enough to lend a hand that would be amazing, thanks in advance.
Depends on codes of course but have you tried disconnecting the battery, turn headlights on with battery disconnected and bridge or touch the negative and positive battery leads' post terminal clamps for a count of ten, or more, turn headlights off, then reconnect battery.
Whilst the battery is off the car I'd take the opportunity to fully recharge the battery, as low and slow as possible, always good to have full battery charge when sorting things or just after.
With the battery reconnected, start the engine, turn headlights and air-con on, (assuming eclectic steering turn the steering full lock both ways) and go for a drive, you can turn headlights and air-con off as soon ass you want.
HTH.
Yes i could help
