The Chronicles Of Verity, The Skoda Octavia
11 hours ago, BadlyTimedExplosion said:
The various warning lights on my dashboard, which lit up like a Christmas tree after I took the steering wheel apart, and refuse to leave (anyone in Sheffield got a VCDS unit handy?)
  • Airbag warning light, which was already on when I bought the car
  • Tyre pressure warning light - I think one of the sensors is busted
  • EPC, Power Steering, TCS/ESP warning lights - all came up after the ignition barrel was swapped over, but car is no less functional and all 3 components work. Need to clear via VCDS
Firstly, congratulations on the Race Blue, the best colour.
Secondly, the quoted faults can all be either fixed (hopefully) or confirmed using VCDS or OBD II. Just cancel them and see if they stay gone.
Thanks! I'm really happy with it myself. Never thought of myself as a blue car kinda girlie, but I do love it, and I've never lost sight of it in a car park yet!
Yeah that's what I'm hoping re. the faults that have come up. Tried with a neighbour's cheap knockoff OBD II unit but no dice there, and I can't justify shelling out for a VCDS unit myself just yet, so the faults shall remain - for now...
On 20/03/2025 at 15:21, MikeTheThinker said:
I suggest a post on the diagnostics forum to see if someone near you can help. I have VCDS here but I'm on the wrong side of the Pennines for you :)
https://www.briskoda.net/forums/forum/23-diagnostics-amp-vcds/
Wrong side of the Pennines only because I no longer live there (I'm from Lancs originally)! Thank you though, that's really helpful - I'll make a post there soon.
Whereabouts are you based in Sheffield? I don't have VCDS but do have a VAG-specific Quicklynks T55 scanner that I used to successfully delete various codes on our pre-facelift 2007 Octy 4x4...
Hey, if it works, it works, right? I'm based south of Sheffield centre - could you message me for further location specifics? Thanks!
For the TPMS fault, the system works using the ABS rather than sensors in the actual wheels, so if you have an ABS fault showing the two will most likely be linked.
Hope you get it all sorted. Keep up the good work!
