Won't charge in 'power save' mode
Good day.
Gor the first time I tried to charge the battery in reduced charcing power mode. I pressed the 'Battery range' in the app, pressed the three dots in the upper right corner, and activated the reduced 'Charging power' option.
The day after, started the car, and battery % was 0%. It didn't charge at all.
I use the 230V wall socket cgarger.
Is it just me, or is it something wrong?
Thanks in advance for any tips and suggestions.
Did you make the change while it was plugged in? Maybe it needs a replug to redo the handshake to get the power supply correct.
Yes. I actually think I did.
I'll try again with a 'fresh start'. Thanks for the tip🙂
