Preamp cable for Symphony HU question
I bought this preamp cable for use with my Symphony:
http://www.bluespot.co.uk/stock/preamp.asp
Connected it all up and couldnt get the Symphony to power up the amp.
I then connected up an aftermarket HU to the blue remote wire and RCAs and it switched the amp on fine, and everything ran ok.
So, I know my wiring install for the amp is good.
Have a bought the wrong cable for the Symphony HU?
If not, and someone confirms I have indeed bought the correct cable from Bluespot I can only assume the Bluespot cable is faulty, and I will send it back for a replacement and try again!
Thanks in advance,
TJ
I think you'll be ok John but you may have to swap one or two of the cables over in the plug. Have a look at the pinouts and see how that compares to your cable -
http://www.fabia-vrs.com/carkit.htm
I've looked into these before but it fell by the wayside.
I have one of these cables taking up space in a drawer at home, pm me your address and I'll pop it in the post for you.
I know it works as I ran my infinity off of it.
Des
Thanks for the offer, Des! PM sent.
Also, thanks for that link VRStu, I will check the pin outs later on when I get home.
