Felicia 1.3 Carb. fuel pump
Hi, i just found an old but not used fuel pump for EVEN older Skoda cars.. and was wondering if it would fit and work properly on my Felicia 1.3 with carburetor if needed?
Has anyone tried?
Thanks,
Igor.
I would have thought it was more about correct fitment to engine. It may not have any significance at all but the pump in the link looks different to another site that states it sells "remanufactured"(?) original parts. As example the arm on the one you linked to has four plates to it against three on other.
Obviously the output rate needs to be correct for carb but I doubt the carb needs much anyway.
https://oldtimer-shop.eu/product/skoda-1000mb-s100-105-120-130-135-fuel-pump-443754340700/
https://www.ostautos24.de/index.php?page=product&info=634 -
Somehow i see only 3 plates in both pumps, i linked those because it was more convenient at the moment, my own pump is in the images below, and it also has 3 plates.
To me it seems like its a good fit, i was just wondering if someone has used such pump for Felicia.
Sorry my mistake, on a closer look yes three plates/fingers to each, the combination of my poor eyes the image and my faulty brain show four for me, I see I was totally wrong now. It's just that I and others have had so many copy/reproduction or alternative parts in the past that are not made as original and can cause issues with fitting and working. My mistake.
