Balancers in cylinder block
Need help if someone have info how balancers in cylinder block are timed to the crankshaft
Superb 2017 crlb engine
If someone have pictures, markings that i made got cleaned accidently
Edited by joca640
I had a lot of trouble finding this info that im sharing, i spoke to 10 mechanics and vag specialist no one had this info.
This info is from car that has 150k km and engine has never been dissasembled, every 2.0 tdi passat, arteon, audi is the same crankshaft and balancer shafts
I setup crankshaft exactly the same as on photos, if you cant put balancer with 2 sprocket exactly just lift crankshaft and turn it 360 deegres till you put it at exact position
Cap oe number 04l 103 113 a
Engine at tdc marking on cover
Edited by joca640
