Help needed please MHI2_ER_SKG13_P4526 file needed.
Just collected a 2019 superb from skoda dealer. Sadly they haven't done all of the software updates.
MIBsolution is down.
Does anyone please have the above update file available or a link?
Thanks all in advance.
i have a link for the AIO (All-In-One) version, that i had downloaded from the mibsolution, before it went down.
"MHI2_ER_SKG13_P4526_1_AIO_MU1440"
whilst the same firmware version - it is not the file u r after though.
this one is used when upgrading from MIB2 to MIB2.5 units.
I think I have it, I will come Back in 1-2 hours.
Thank you very much.
Thank you so very much.
If I may hijack this thread :)
I have also just recently purchased a 2018 L&K, and it seems like the firmware and the maps have never been updated:
The map files I have downloaded from the Skoda portal are "HIGH2_P410_EU_202522". When I insert it via my portable 1TB SSD (I know this could be the problem), with exfat format and only the files, the sytem doesn't see any update files.
Also, while on my Infotainment Online trial subscription, I tried the Online update, but that doesn't seem to lead anywhere, it gets stuck in one place at EU common. If I choose only one country to update, then it runs towards the end, and stops at around 90% and doesn't do anything even after an hour.
I have also heard that I might not be able to update from 0166 to the current version directly, but I need 308 (?) first.
Can you direct me into the correct direction, and maybe correct files as well?
I guess I'll need:
  • newest firmware (couldn't download, as mibsolution.one is down)
  • 308 database
  • newest database
Thanks!
Hi there.
Sorry for the delay in replying.
I used a 32gb USB stick exFAT format. The map update was 16gb unzipped.
Unzipped into the root directory.
Recognised straight away when updating via the system information in settings.
Took about an hour and has updated to 2025.
My MIB won't update online despite a trial subscription. Ive tried mobile hot-spot, connecting to home Wi-Fi and an inbuilt data sim in glove box.
Keeps saying licence invalid.
MIBsolution as you said is unavailable.
Mine is an approved used so I will be taking it to the dealer for them to sort out.
Skoda connect customer service weren't knowledgeable about it.
Just as an update to this - mibsolution appears back up and running. MIB3 only has v332 now though so they may have had a bit of a cleanup of older files in case anything can't be found...
Thank you
Edited by BratusMaximus
