Octavia dash functions and cruise control
Hi
I have a 2010 Octavia 1.6TDI CR which I believe to be the base model.
My dash display tells me outside temperature and trip...that is all.
The car has no cruise control on the light stalk or extra buttons on the wiper stalk, can I change the stalks for ones with the extra buttons, and will doing so allow me to do more with the dash and have cruise control?
Thanks in advance!
Hi, to be completely sure, I advise you to do a complete autoscan via VCDS to determine which module and unit you have and determine what parts you will need (for example, there are two types of stalks, one composed of two singular stalks, and in this case, the needed one is just the left, and the other case is just a single assembly) just to understand how to proceed. Because looking online, it seems for the mid and high trim, the stalk replacement and coding are all that are needed, but I believe in your case, also some wiring will be needed. Online, and on Briskoda, there are a lot of guides.
For example, here there is some useful info:
https://www.briskoda.net/forums/topic/307988-retrofitting-cruise-control/?fromsearch=1
Thanks for coming back to me, I have managed to go and do a scan as follows...
Chassis Type: 1Z-SK35 (1K0)
Scan: 01 03 08 09 10 15 16 17 19 25 42 44 46 52 56
VIN: TMBJT21Z7A2124342 Mileage: 225500km-140119miles
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
Address 01: Engine (J623-CAYC) Labels:. 03L-906-023-CAY.clb
Part No SW: 03L 906 023 AG HW: 03L 906 023 AG
Component: R4 1.6l TDI H23 9979
Revision: --H23--- Serial number: CVN: 433ED292
Coding: 00114014030500080000
Shop #: WSC 73430 031 00999
ASAM Dataset: EV_ECM16TDI02103L906023AG 003014
ROD: EV_ECM16TDI02103L906023AG_003.rod
VCID: 6BD572AB8285F9CE06-803E
VINID: 91D49A90206A1D10810840C40892846E10
No fault code found.
Readiness: 0 0 0 0 1
Address 03: ABS Brakes Labels:. 1K0-907-379-MK70M.clb
Part No SW: 1K0 907 379 AK HW: 1K0 907 379 AK
Component: MK70 M MASR 0105
Revision: 00H35001
Coding: 0017665
Shop #: WSC 73430 790 00999
VCID: 7BF542EB3AE5694E96-802E
Address 08: Auto HVAC (J301) Labels:| 3C8-907-336.clb
Part No SW: 3T0 820 047 M HW: 3T0 820 047 M
Component: Climatic 150 0303
Revision: 00006001
Coding: 0000000002
ASAM Dataset: EV_Climatic A01005
ROD: EV_ClimaBasis_SK35.rod
VCID: 397998E3B8599B5EC4-806C
1 Fault Found:
9481200 - Refrigerant Pressure
B10AB F0 [00001001] - Too Low
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 239
Mileage: 225508 km
Date: 2025.06.03.
Time: 13:09:15
Address 09: Cent. Elect. (J519) Labels:. 1K0-937-08x-09.clb
Part No SW: 1K0 937 085 D HW: 1K0 937 085 D
Component: BCM PQ35 B+ 103 0575
Revision: 00103 AG
Coding: 48180AB8B0050CB04010008001000024430000AE424D81605C4440000000
VCID: 306FA5C763235A1673-8064
Subsystem 1 - Part No: 1Z2 955 119 C Labels: 1KX-955-119.CLB
Component: Wischer 29041 22 0601
Coding: 00D7B7
Address 10: Park/Steer Assist (J446) Labels:. 1Z0-919-475-V1.clb
Part No SW: 1Z0 919 475 B HW: 1Z0 919 475
Component: PARKHILFE 4K H06 0006
Revision: -------- Serial number: 66641011806276
Coding: 100001
VCID: 408FF507D383CA9683-8014
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 T HW: 1K0 909 605 T
Component: Q4 AIRBAG VW8 020 2300
Revision: 05020000 Serial number: 0038PD2LSLVN
Coding: 0020788
VCID: 3D718CF36471A77EE8-8068
Subsystem 1 - Serial number: 6332MSME52724D52B
Subsystem 2 - Serial number: 6342MSME35312614/
Address 16: Steering wheel Labels: 1K0-953-549-MY9.lbl
Part No SW: 1K0 953 549 DA HW: 1K0 953 549 DA
Component: J0527 053 0111
Coding: 0000002
VCID: 74E769D717BB2636D7-8020
Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb-SRI1
Part No SW: 1Z0 920 903 G HW: 1Z0 920 903 G
Component: KOMBI H06 0305
Serial number: 00000000000000
Coding: 410300
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04052
ROD: EV_Kombi_UDS_VDD_RM09_004_SK35.rod
Address 19: CAN Gateway Labels:. 1K0-907-530-V4.clb
Part No SW: 1K0 907 530 AD HW: 1K0 907 951
Component: J533 Gateway H16 0233
Revision: H16 Serial number: 4520K105060244
Coding: E9A01F06000202002303
VCID: 69D908A34079EBDE74-803C
Address 25: Immobilizer (J334) Labels:| 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H06 0305
Coding: 000000
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03005
ROD: EV_Immo_UDS_VDD_RM09_VW21.rod
VCID: 6ADB77AF8D7FE0C67D-803E
Address 42: Door Elect, Driver Labels:. 1K0-959-701-MIN3.clb
Part No SW: 1T0 959 701 T HW: 1T0 959 701 T
Component: Tuer-SG 009 2114
Coding: 0000564
VCID: 489FED273BB3F2D64B-801C
Address 44: Steering Assist Labels: 1K0-909-14x-GEN3.clb
Part No: 1K0 909 144 J
Component: EPS_ZFLS Kl. 68 3001
Revision: 00H17000
VCID: 3169A0C3A829531E7C-8064
Address 52: Door Elect, Pass. Labels:. 1K0-959-702-MIN3.clb
Part No SW: 1T0 959 702 D HW: 1T0 959 702 D
Component: Tuer-SG 006 1204
Coding: 0000564
Shop #: WSC 73430 790 00000
VCID: 397998E370599B5EC4-806C
Address 56: Radio (J503) Labels:. 5M0-035-1xx-56.clb
Part No SW: 1Z0 035 161 G HW: 1Z0 035 161 G
Component: Radio-SWING 009 0030
Revision: -----12S Serial number: SKZ4Z2K1202093
Coding: 080002000001
VCID: 326BAFCF6D2F680605-8066
Also did a scan on just 17...
Control Module Part Number: 1Z0 920 903 G
Component and/or Version: KOMBI H06 0305
Software Coding: 110300
Work Shop Code: WSC 73430
Advanced Identification/FAZIT
Identification: VD1-048
Date: 05.05.10
Manufacturer number: 5250
Test stand number: 4941
Flash Status
Programming Attempts(application): 0/0/5/0/0/0/0/0/0/0
Successful Attempts(application): 0/0/0/0/0/0/0/0/0/0
Programming Status: 00000000
Flash Date: 00.00.00
Software
OSEK-OS: 03.14.00
HiSpd Net: 01.10.00
Misc.
Hardware number: 1Z0 920 903 G
Workshop System Name: J285
Equipment/PR Code: 2D2D2D2D2D2D2D2D
Dataset Number: -----------
Dataset Version: ----
End of Line Equipment Level: ------------------
ASAM Dataset Revision: A04052
Car Info
Chassis Number: TMBJT21Z7A2124342
VCDS Info:
Labels: 5K0-920-xxx-17.clb-SRI1
Hopefully this is of use!
Thank you, (I've run the VIN via skodaparts to check the components). Judging just by the number of pins between your steering unit 1K0 953 549 DA and the other available (medium and high versions), there are a lot of pin differences. I've found this website that sells the CC retrofit kit where you can ask for info about:
https://wibutec-shop.com/Retrofit-kit-GRA-cruise-control-system-Skoda-Octavia-1Z-from-02-2004-to-05-2010
If you enter your VIN code, the price will go up to €364 because you don't have a multi-function display, which is related to the steering module (cruise control MFSW, etc.), so I believe the retrofit kit will include the module, stalk and wiring.
Also, considering the fact that you have access to VCDS, see if you can enable it just out of curiosity, but I am really sure that it will not work.
Thankyou so much for doing all that for me, looks like I will probably give up on the cruise control dream, dont really want to start pouring money into the old girl!
Just to tick the box, what option would I be enabling in VCDS?
Any idea about the dash display and if there's a way of it showing things like consumption, not just the outside temperature?
You're welcome, happy to help. You can try to ask that company and see what they say, and if they give you any part number or idea of what you need, you can look for them used on eBay or a local scrapyard. For the cluster function on the VCDS "home page" there is the cluster menu called 17 - Instrument. In my Fabia (I've done a lot of upgrades and retrofits like rear electric windows), for example, I've managed to modify the service interval from 15k km to 10k km (I prefer to do the service earlier to preserve the timing chain and general engine life) and also to enable the washer fluid warning light (one wire to the cluster and the sensor in the washer bottle), and enabling the liter of fuel that is needed to fill up or needle sweep. That's just for the cluster. I don't have the Maxidot, so the functions are a bit limited. You can also look for other modules, especially for the comfort module / central electrics, to enable other functions like opening the window by pressing the unlock button on the keyfob and things like that, also in the abs module I'm not sure if you have a newer gen of abs unit, but you can try to look for tpms (it uses the abs sensor to determine the tire rotation to detect if all the wheel are rotating the same way if not there is an air leak and the warning light turn on but the only way to reset it is via vcds or retroffitting the switch) and also automatic hill hold if you are stopped up hill or down hill while having clutch and brake pressed the car stay stand still for about 3 to 4 second allowing you to move without the handbrake method (I've learned that way, but some electronic helping is not always bad).
For the temperature depends on whether there is a thermometer (installed probably yes) and for fuel consumption, I believe it is possible.
Edited by Jack25
