OCU Fault codes - How do I fix this?
The below are the fault codes for the OCU in my car. (The entire log is attached).
Is this likely to be a software fix, or am I looking at a part replacement?
Address 75: Telematics (J949) Labels:* None
Part No SW: 5WA 035 284 G HW: 5WA 035 284
Component: OCUGen3High H20 0143
Serial number: 0000000911VICL1 Dataset Number: V03935425BX 0001
Coding: 034820101969A8819005460161052E07
ASAM Dataset: EV_OCUGen3High 003007
ROD: EV_OCUGen3High_003_VW41.rod
VCID: 4ACD75D0AC39174A11E-801E
2 Faults Found:
0081 - Databus
U1121 00 [00001000] - Missing Message
[Ethernet Databus missing message - Infotainment Unit]
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 6
Fault Frequency: 21
Reset counter: 40
Mileage: 52727 km
Date: 2024.12.21
Time: 16:04:35
Voltage terminal 30: 13.0 V
13631561 - Internal Control Module Memory Check Sum Error
B2000 49 [00001001] - Internal Electronic Failure
[Control unit defective Analog circuitry]
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Mileage: 52143 km
Date: 2024.11.22
Time: 07:00:04
Voltage terminal 30: 12.5 V
Log-TMBJW7NPXL7062163-58458km-36324mi-KDG.txt
Hi,
What symptoms do you face? I mean, what were you looking for when making this scan?
I understand, you tried to erase fault codes in module 75-Telematics and you looked int the long coding on this module too.
Did you intend change something?
Considering there are a lot of DTCs, and some of them already have several months. I would suggest erasing all of them and making a new scan to see which ones actually remain. I feel module 75 may not be the culprit.
BTW, did you ask on the ross-tech forum (assuming your HEX-V2, is an original one)? They saved me 3 or 4 times or at least they helped me checking that my dealer did not try to fool me... 😉
"B2000 49 [00001001] - Internal Electronic Failure
[Control unit defective Analog circuitry]"
based on this fault code, i would assume ur telematics control unit is no good at all and will need to b replaced entirely.
I have the dreaded "SOS call fault: please visit workshop"
This appeared shortly after the dealer updated my software last year.
Edited by CageyH
OK. I think @JR RS may be right.
Do you plan to erase all fault codes and make another scan?
I have already tried this.
It does not work.
Ok, new scan done.
Less errors
It helps when you follow the instructions of the VCDS. 😉
I will upload the file later.
I made an error with the VCDS and selected the car make and model, rather than doing a CAN auto select scan. 🤡
New full scan attached. My thoughts are (hopefully) it is a software issue (based on the J794 1555 - Check Software Version Management error code).
Key points below:
Address 17: Instruments (J285) Labels:| 5G0-920-XXX-17.clb-SRI3
Part No SW: 3V0 920 794 A HW: 3V0 920 794 A
Component: KOMBI 503 4194
Coding: 05A50B1A778C0008018C621B1001000880600000
Shop #: WSC 00033 790 00180
ASAM Dataset: EV_DashBoardVDDMQBA0 001042
ROD: EV_DashBoardVDDMQBA0_001_VW37.rod
VCID: 392F3A1CF9DF8CD2887-806C
2 Faults Found:
1048578 - No Basic Setting
B2010 00 [00001001] - -
[Steuerger t keine oder falsche Grundeinstellung]
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 132
Mileage: 58507 km
Date: 2025.06.06
Time: 13:37:49
16777056 - Function Restricted due to Interrupted Communications
U1110 00 [00001001] - -
[BAP_SDS_0x46 keine Kommunikation]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 132
Mileage: 58507 km
Date: 2025.06.06
Time: 13:37:49
Address 5F: Information Electr. (J794) Labels:| 3G5-035-MIB-HGH3.clb
Part No SW: 3V0 035 820 B HW: 3V0 035 820
Component: MU-O-ND-EU H12 0330
Serial number: SKZAZ2X0513959 Dataset Number: V03935353QH 0001
Coding: 34820020000020000000000000000000000000000000000000
ASAM Dataset: EV_MUOIMQB 001001
ROD: EV_MUOIMQB_001_SK48.rod
VCID: 2D071E4C3D97207214F-8078
1 Fault Found:
B201A 00 [00001001] - -
[Check software version management]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 40
Mileage: 58507 km
Date: 2025.06.06
Time: 13:37:49
Voltage terminal 30: 13.1 V
module_name:
VCID: 4ACD75D0AC39174A11D-801E
1 Fault Found:
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Mileage: 52143 km
Date: 2024.11.22
Time: 07:00:04
Log-TMBJW7NPXL7062163-58507km-36354mi-KG.txt
I have cleared the 5F fault.
Three faults.
Everything but the 5F, so I think we are looking at a replacement OCU3.
  • 10 months later...
A small update on this point.
Unbeknown to me, I had an extended warranty on the car when I bought it, so alI finally took the car in to get it fixed on Monday (after the service, fault check, warranty claim etc.) and I was told that it is not the OCU that needs changing, but a smaller, less expensive part.
I don't have the detail yet, but the car is going back in on Friday for the fix. Total cost is about €200. I will update the detail when I have it.
Back from the garage. An SOS repair kit was fitted (part number 5WA998085C) which costs less than €10 but including the labour, it cost me less than €200.
Much better than the cost of replacing the OCU itself.
