Kodiaq steering wheel vibration
12 hours ago, AndyMi said:
Whats your production date? I have much less vibrations after both dcc and top strut mounts change. But my car still feels more pathholes than normal i think - it could be ball joint that will be changed
Date of manufaktured is 30 05 2026
Date of manufaktured is 30 05 2026HelliHello guys, is the problem witaj vibrations solved?
I havevthe same problem with my new skoda. Skoda warianty servicd said that it is normal. I couldnt find solution on polish forums. That the
Hello,
I have same issue with kodiaq 2.0tsi 4x4. In Poland warranty service said that every VAG car have some vibration problem. I changed mc person bearings and gearbox mount. Nothing change with vibrations.
User Akodiaq please contact priv
I changed on warranty right ball joint and left bearing, they also changed both back silentblock of front arms and I have small vibration back again. In my opinion, this is resonance of system from the road or its steering rack
What you think about halfshaft or CV joints? In my opiniom resonance come from floor on passenger site also.
They said that resonance on steering wheel could by coused by many electric engines of assistant system. Those systems are directly connect with steering rack.
Dont think that Its halfshaft, i didnt have vibrations after some changes, but now i got some small, halfshaft will vibrate on acceleration. Steering rack has some difficulties and I hear some strange noises even when both shock absorbers are charged
Ive found on some polish forum that its possible that those OEM silentbock are to "soft". Some users replacw them Audi S3 silent block,
45 minutes ago, KamilM said:
Hello friend from Poland I cant write priv message
Hello,
2 hours ago, KamilM said:
Hello,
Hello friend i cant writer prive because is not allow for fresh users. You Can find me on PL forum kodiaq The same nick.
In accordance to this problem i solved it. I will describe it Heare when i ll find morę time.
Great news!!!
Please dont forget about me!!! Hope that it will work also in my car!
 Herę You arę. Wrap the fabric wiring-harness tape around once,
as shown in the photo, without any overlap.
Once compressed, the tape is approximately 0.11 mm thick, resulting in a clearance of over 0.22 mm—I’m not sure if that’s considered significant or not, but it does affect how the wheel centers itself during installation.
Also, I would suggest tightening the wheel bolts while the wheel is unloaded; lower the vehicle only enough to keep the wheel from spinning while you tighten them.
Let me know if this helps in your case. I’d also appreciate hearing from others
Edited by Akodiaq
Hello, i don’t think that’s the solution. It can’t be so sensitive. I guess that after changing my front silentblocks for new ones vibration is slightly back. Car is more stable but vibrate sometimes. I found better solution - drive 140+ and there is no vibration at all
Please try to do it and give feedback. In my case bring possitive results. Generally i Heard that the problem in vag group.
Did you mean that this issue with wheel centring? This tape could solve issue when u do not have OE wheels, but my car vibrates only sometimes- on the same speed on TA sometimes vibrates and sometimes not
Yeah,
I meassured dimension on every wheels,
Its aproximetely 0,2mm difference between center and wheel - OEM.
Orginal bolt are spherical, thats why it centre by this surface not by the center hub.
I used insulatoon tape 0,13, in my opinion, vibration still exist. Of course you have right, 0,2mm its too much.
10 minutes ago, KamilM said:
Yeah,
Now it is time to Check you tires. Go to road hunter test. Test ocour road force in simulation with load. IF the road force were under 60 niutons it should be ok. But tire technican Can optymalize set of tire in realiom to wheel ring. I had to throw away 2 tires because road force was ocet 100 niutons
So now you got no vibration at all?
Recently Browsing 2
