Posted
0...... How to debug , I dont know where to start debugging, Fuses are fine.
Have read that if the brake light switch fails it can do this. Check the brake lights are working.
Alasdair
Look for a broken wire just outside cable entry of starter solenoid connector.
@Alasdair1 Break switch is working properly.
@Breezy_Pete I got starter serviced and tried to start, but it still the same, might be some problem in ECU . Should I open ECU , or generally their wont be a problem. Does blocked DPF cause problem to initiate starter.
Edited by akshaykumarhegde
If you did not find a broken wire in the location I described then my idea is not correct.
Engine ECUs are incredibly reliable in recent cars. Very, very unlikely to be that.
