Fabia Mk1 accelerator pedal kit ?
Hi..
I think I need to replace the accelerator pedal kit on our Fabia as the throttle valve isn't opening.
Checked the operation of the valve on my bench and its fine.
Problem is, finding the replacement number of the pedal assembly before I remove the old one. New ones are all pointed at LHD cars.
Ours is a 6Y2..
2006 Fabia 1 1.4 16v (75hp) automatic RHD.
Does anyone know the correct part no. for this item? I'm getting such a variation in numbers when I look around.. 🤔
  • Sponsor
Reg or VIN and I can look up for you.
I'd be surprised if a faulty pedal didn't generate fault codes though. There are dual opposite-direction potentiometers in there, just as there are within the throttle body. All monitored for discrepancies I believe.
Edited by Breezy_Pete
Doubts over diagnostics
