gearbox dogbone mount bushes replacement.
Hi there I reckon I may need to change the bushes that the dogbone gearbox/engine bracket use in the subframe.. Is there an easy way to do it or do I have to drop subframe to remove old bushes and press new ones in. Read somewhere about a polybush replacement/conversion but that may have been for a fabia.
Alasdair
Google Dogbone mount poly insert and you can do it with the mount in place, it just fills the gaps in the bush with poly.
Many thanks. Thats what I had read but didnt think/couldnt remember its an insert. I kept coming up with complete bushing. Will have a look
Alasdair
