VCDS options on Kodiaq I. FL
OK. My bad. I lost something in translation indeed. I've asked a moderator to remove my message on the S&S mod.
The coding was accept though and I didn't drive that much since I've made it. This why it fooled me.
Thanks for having clarified your sayings.
Cheers.
Edited by Bap33
Cheers.
Yes as I have found it appears to have accepted the coding but nothing changes. I wish it did but have learned to live with it. If only I could get the speed sign icon to appear in the dash like it did in the Tiguan I would be happy but no go on that either even though it is ticked in the settings in the MMI . A lot of this stuff went to crap when they changed the camera version and ever since then stuff has stopped being to be changed It went from a 3Q to a 2Q or other way but if you look at newer instructions it says " must have ?Q camera to work" Also some stuff is now in different modules which has also upset things.. In all my mods the paths are correct as all worked but in later models stuff isnt where I expect to find it.. This is a fairly good Forum www.watercooled.com and https://www.autoinstruct.com.au/ While both are VW a lot still applies as I have mainly used the Mk7 stuff for the Tiguan
12 minutes ago, Exkiwi said:
Ja, ich habe festgestellt, dass die Codierung scheinbar akzeptiert wurde, aber es ändert sich nichts. Ich wünschte, es wäre so, aber ich habe gelernt, damit zu leben. Wenn ich nur das Geschwindigkeitssymbol im Armaturenbrett anzeigen lassen könnte, wie beim Tiguan, wäre ich glücklich, aber auch das funktioniert nicht, obwohl es in den MMI-Einstellungen aktiviert ist. Vieles davon ging den Bach runter, als die Kameraversion geändert wurde, und seitdem kann nichts mehr geändert werden. Von 3Q auf 2Q oder so, aber in neueren Anleitungen heißt es: „Für den Betrieb ist eine ?Q-Kamera erforderlich.“ Außerdem befinden sich einige Dinge jetzt in anderen Modulen, was die Dinge ebenfalls durcheinandergebracht hat. In all meinen Modifikationen sind die Pfade korrekt, da alles funktioniert hat, aber in späteren Modellen sind die Dinge nicht dort, wo ich sie erwarte. Dies sind ziemlich gute Foren: www.watercooled.com und https://www.autoinstruct.com.au/ . Obwohl beide von VW sind, gilt vieles immer noch, da ich hauptsächlich die Mk7-Sachen für den Tiguan verwendet habe.
Do you know that you can now patch the 2Q camera for traffic sign recognition?
And just as a note, please note the differences between coding and adjustment. The voltage trick for start-stop is an adjustment
Edited by Cairus
20 hours ago, Cairus said:
I don't question their work, but it may not work in the next model year, etc., so I think control unit information is quite important.
Jeez... Why so much arguing over stop start... And why so much concern about turning it off... It's not particularly intrusive or damaging.
17 minutes ago, skomaz said:
Herrgott ... Warum gibt es so viele Diskussionen über die Start-Stopp-Funktion ... Und warum so viele Bedenken hinsichtlich des Ausschaltens ... Es ist weder besonders aufdringlich noch schädlich.
You don't understand the translation 100% correctly... I have no problem at all when it's deactivated. I spent days looking through the gateway's data sets to see if it can still be deactivated. I'm concerned about the incorrect information. The first post says it was tested on the vehicle and works. That's a false statement for a 2022 model year vehicle. Many people think it works and copy it, but then it doesn't work.
The post including this adaptation has been removed by a moderator since this morning. It ain’t an issue anymore now.
Edited by Bap33
So if there is a patch for the camera could you post the details so we can try it
8 hours ago, Exkiwi said:
Wenn es also einen Patch für die Kamera gibt, könnten Sie die Details posten, damit wir ihn ausprobieren können
Danke
You have Odis? Vcp or VC Tool?
GeKo for CP?
Edited by Cairus
  • Lee01 pinned this topic
  • 3 months later...
On 17/07/2025 at 13:47, Cairus said:
Look Here:
https://wiki-online.vcds.de/de/Codierungen/MQB/Licht/US-Standlicht
"Hi, I have a request regarding my Kodiaq (2019 RS). I was coding the US side marker feature (US daytime running lights/coding), but it didn't work out as expected, even though I followed the instructions. Unfortunately, the backup wasn't saved correctly either... Instead of the US side markers, my front fog lights are now on when the low beams are activated. I need to revert this change. Would a basic settings reset of the lights be enough? Also, if you happen to have a backup file, I would be very grateful. Thank you for your help."
Factory Reset dont Help
"And do you have any ideas on how to fix this? And if I performed a reset via ODIS, would that still not work? When I get the car back, I'd be happy to send any necessary values. Thank you very much for your response."
You have To Code step by step own.
Or service Station with Odis online SVM Coding
Edited by Cairus
AFAIK, Basic setting only changes values, but it doesn't deal with coding nor adaptations.
Thus, you can make as many basic settings as you want, I fear it won't bring you back to the original coding...
As @Cairus said, getting back to your original coding should be the lonely solution.
Edited by Bap33
Recently Browsing 1
