DIY: How to Remove Chrome from Skoda Emblem and Steering Wheel Trim
Hello everyone, If you're like me and not a fan of chrome details, this quick guide might be for you.
I did this because I didn’t like the chrome on the steering wheel and I wanted a completely black emblem. So I bought a new emblem (part number 5E3 853 621 C FOD) for 18 euros and followed the steps below.
While upgrading the steering wheel to a new one with a touch sensor and a Travel Assist button, I decided to give this a try.
⚠️ Disclaimer: This is a DIY project that you do at your own risk. I'm simply sharing what worked for me — if something goes wrong, please don’t blame me 😄. Always follow safety guidelines and use proper protection when working with chemicals or tools.
What you'll need:
Steps:
1. Removing the Emblem:
Remove the emblem, peel off any adhesive tape, and break off the small tabs on the back that hold the chrome part. These will be reattached later using superglue.
2. Disassembling the Steering Wheel:
Remove the steering wheel, take out the control buttons, and gently detach the trim from the button assembly.
Preparing the Parts:
1. Sanding:
Since the front emblem and trims have a lacquer coating over the chrome, a light sanding is required so the solution can work effectively. Use 400-grit sandpaper for this.
2. Chrome Removal:
Fully submerge the parts in ferric chloride and leave them to soak.
(For me, it took around 24 hours.)
According to the instructions, the higher the temperature, the faster the dechroming process.
3. Final Cleaning:
In some areas, the chrome didn’t come off completely. I used the abrasive side of a kitchen sponge to remove the softened chrome. This doesn’t scratch the plastic but helps eliminate remaining residue.
Next Steps:
Apply primer, then paint, then clear coat.
I painted the emblem myself using matte black spray paint, but for the steering wheel trim, I took it to a professional painter to get a perfect piano black finish.
Final Step:
Reassemble everything
WhatsApp Image 2025-07-15 at 11.58.52.jpegWhatsApp Image 2025-07-15 at 11.58.58.jpeg.WhatsApp Image 2025-07-15 at 11.57.37.jpeg
That’s it! Hopefully, this helps you get the look you want without breaking the bank. Enjoy your sleek, customized Skoda interior! If you try it yourself, have fun and stay safe!
