P03AA00 Cylinder 3 Pressure sensor range/performance - Software update / TSB??
Hi all.
I've had my 70 plate Kodiaq Diesel 2.0 in again today, for the above fault. A couple of months ago, the glow plug with integrated pressure sensor was replaced, and the EML went away. In the last few weeks, it has been back intermittantly with the same fault.
Took it back to the garage today, and they (without getting auth, I will add) did a software update on it - apparently advised by Skoda Technical Services. This is apparently the subject of a TSB or some such similar acronym!
Has anyone on here had similar experience, or can anyone shed any light on a TSB for the above fault? It all sounds a bit weird to me.
Ta.
GrumpyMike
Did the software update fix your issue? I have a Kodiaq 2.0tsi 200bhp DTUA with the exact same issue…
Not much help, I know, but I had that fault on our 67 plate 2 litre (150) diesel and I bought a genuine glow plug (03L905061 L) and fitted it. It just worked fine after that (July 2024). No software updated needed.
