OBD11 Coding list for Octavia MK4 / IV
  • wanker10 changed the title to OBD11 Coding list for Octavia MK4 / IV
Would genuinely love to apply a couple of these, however, having read through plenty of posts regarding software issues I'm not keen to start messing about. Would be interesting to hear others thoughts, perhaps those who've applied any of these?
Anyone got any they can add to these? Considering purchasing an OBDEleven unit to try a few of these out...
On 02/08/2025 at 10:28, ****er10 said:
Since I had a really hard time gathering some popular options to be coded on my Octavia MK4 while avoiding one click apps, I figured it would be nice to post a summary of my findings so far. Some I haven't tested so please do let me know if they work. Would also appreciate if some can be added. It really sucks there is not a big list of features for this car to be coded, one click apps are too expensive.
Lighting & Displays
Fan Speed Display in AUTO Mode
  • Description: Shows the current fan speed level on the climate control display even when it's in full AUTO mode.
  • Control Unit: 08 - Air Conditioning
  • Path: Adaptation
  • Parameter: Blower display in auto operation
  • New Value: activated
High Beam Assist - Remember Last Setting
  • Description: The car will remember your last setting for the automatic high beam assistant, so you don't have to re-enable it on every drive.
  • Control Unit: 09 - Central Electrics
  • Path: Adaptation > Fernlicht_assistent
  • Parameter: Fernlichtassistent Reset
  • New Value: not_active
Pulsating Start Button Light
  • Description: Makes the engine start/stop button pulsate with a "heartbeat" effect before the ignition is turned on.
  • Control Unit: B7 - Access Startsystem Interface
  • Path: Adaptation > DeveloperCoding: Search lights
  • Parameter 1: ZATillumination_concept_mybeat_clamp58xt
  • Parameter 2: ZATillumination_modus_mybeat_clamp58xt
Enable Rear DRLs (Scandinavian DRLs)
  • Description: Activates the rear taillights to stay on with the front Daytime Running Lights (DRLs).
  • Path: Adaptation > Daytime running light
  • Parameter: Tagfahrlicht-Dauerfahrlicht aktiviert zusaetzlich Standlicht
  • New Value: aktiv
Change Tachometer Style
  • Description: Changes the visual style and max speed value of the tachometer in the virtual cockpit.
  • Control Unit: 17 - Instruments
  • Path: Adaptation
  • Parameter: Tachometer end value
  • New Value: Choose a different version number (e.g., from Version 2 to Version 6). Requires ignition cycle to apply.
Deactivate Headlight Washer System
  • Description: Prevents the headlight washers from activating when you use the windshield washers.
  • Path: Adaptation > Scheinwerferreinigung
  • Parameter 1: Anzahl Betaetigungen Frontwaschanlage pro SRA Aktivierung
  • New Value: Change from the default (e.g., 10) to a very high number like 255.
  • Parameter 2: SRA bei waschwassermangel
  • New Value: not active
Fade In/Out Interior Lighting
  • Description: Adds a smooth fade effect when the interior lights turn on and off.
  • Control Unit: 09 - Central Electrics (Security Access Code: 31347)
  • Path: Adaptation > Suchbeleuchtung allgemein
  • Parameter: KL58 einschalten mit rampe
  • New Value: aktiv
Ist there a way to make the ambientlight brighter? In my opinion it is too dark and maybe there is a coding for it? Thanks for any help!
Edited by Lukas_2611
  • 4 months later...
Caved in and bought an OBDEleven device + Pro plan in their recent sale...
Have attempted to activate standard cruise control numerous times via the above method but it doesn't work.
I've read elsewhere that you can only do it via One Click Apps, could it be that OBD11 have now blocked you from manually coding it?
Real shame like as I've implemented a few other bits and bobs, some from above and others I found elsewhere. It's a really nifty bit of kit, can't tell you how it feels to no longer have to manually switch off lane assist every time I get in the car 😄
Not really wanting to use One Click Apps after reading in some places that they can cause issues, but if it's now the only way to enable standard CC..... 🫤
Edited by scotthugh3s
can tell I'm new to OBD11, turns out I haven't been using the security access code, didn't know I had to lol
what's your car? The Octavia 4 facelift has SFD2 Protection, meaning most of the control units are locked and OBD11 cannot write. Some units can be temporarily unlocked, but it will not work everywhere tho.
I have pre facelift Octavia IV.
I managed to activate standard CC in the end, I didn't realise to make changes on that particular module you have to enter a security code, DOH!
  • 5 months later...
Where do you find the security code?
OBD11 will usually find it for you, as in show it on screen, but you then have to manually enter it yourself. That's the bit that was confusing me, it would come up with the security access code (don't recall it off the top of my head, something like 30407 though) but you then have to input that yourself. I thought cos it was showing it to me, that was it, but apparently not
Thank you for that. I am going to order the device with the Pro Pack.
That's what I did a few months back, no regrets whatsoever
To my surprise, having steeled myself to pay £119 for the device with a year's subscription, there was a code to get 30% off. I tried to order from the website and pay by card, at £90 and some pence including postage, but their website would not accept my full address, so I changed to PayPal, and paid £88.22 because postage was less that way!
Yep, got a similar deal myself (paid around the £90 mark anyway) My next piece of advice though would be to buy a battery charger. I recommend the CTEK MXS 5.0 although I've heard good things about the NOCO Genius 5 too
If you're going to spend any amount of time messing around with OBD11, which you undoubtedly will as you familiarise yourself with it, then you'll need to be hooked up to a charger to prevent your battery from dropping out on you unexpectedly, which can in turn lead to more complicated errors as I'm sure you're aware
Thank you. I have a CTEK MXS 5.0. When I had my Jaguar XK it had to be connected 24/7. When not in use they are notorious for discharging their batteries due to all the electronics that never switch off.
Now I really need help. I have ordered the OBD11 device, and went to the car to locate the OBD2 port. I cannot find it. I was told it is in the drivers foot well, above the foot rest. It is not, nor can I find one anywhere else. Can anyone point me to the correct place. Is it behind the dropdown cubbyhole? I have tried and failed to look behind it. Every other car with OBD that I have owned (Saab, Jaguar and Seat) has had the OBD2 port clearly visible and accessible, but not this Skoda, which is a 2024 Octavia Vrs diesel.
I have now found it. It is easy if you can get on your back with your head in the driver's foot well, not so easy if you are 80 and not as flexible as you used to be. Mine has no cover and is coloured mauve.
I had been expecting to find a pull off cover, probably black.
Precisely what they were discussing on the other topic mentioned above...
No cover on most of the new cars; probably one might find covered OBD port on some premium models.
Device came today. After a lot of fiddling to get my credit and subscription to load, I have coded the Lane Assist, Cruise Control and Daytime Running Lights as shown above.
Thank you W.....10
Edited by NormanE
typo
Road test. Lane assist off Good! Daytime running lights on. (Skandinavian, with rear lights on)
Cruise control still adaptive, with no visible means of switching it to work as a plain cruise control. On the screen, in Assist Systems it only shows up as ACC.
Edited by NormanE
You have to make it visible IIRC, use the buttons on your steering wheel to bring up menus, then check the box next to Cruise Control / Speed Limiter etc
CCS IS Coding Unit 13&17
Edited by Cairus
Thank you all. I had been looking at the wrong screen and forgetting the steering wheel buttons. All is now good.
