220v power outlet
I have a 2017 Skoda Kodiaq (originally Dutch, later registered in Italy). It has the rear 220V socket and USB port, but both seem disabled. The USB gives 5V for a split second and then shuts off, regardless of the load. Fuses are all fine.
Could this be disabled via CAN settings? Can anyone confirm?
They only work with engine on and about 5 min after the engine is off. If that`s the problem.
thanks @linni unfortunately i tested both with the engine on.
