Help! Temp dropping
Hoping someone can help with this as I’m out of ideas.
Coolant temp needle drops when I turn heating on
Main thermostat replaced
Dsg inline thermostat replaced
All coolant temp sensors changed
Fresh coolant
New waterpump
0 fault codes , scanned using vcds
All genuine parts
Heaters are HOT when on Hi, but if I turn it down 1 notch it is cooler
CFGB
Any ideas?
From what temp to what new temp
I'd expect a drop of 5-10 egrees pretty normal
Bit surprised the guage shows it but....I thought they were pretty sticky around 90 degrees
On 19/08/2025 at 18:36, Gtd80y said:
Fresh coolant
Did you vacuum fill or just pour it into the expansion tank?
When changing the coolant this year I had to use a vacuum to fully fill with the new coolant.
Kev.
May be an airlock somewhere. Could be in the heater matrix
Alasdair
  • 7 months later...
No air lock, tried back flushing heater matrix aswell and flow was good. Needle only drops when heaters go on otherwise stays solid 90
The new thermostat. Was it the correct one. I have heard of different ones for cold or hot climate?
Yes it was a brand new genuine part from TPS, fitted at a VW specialist. The car takes 11 mins to hit 90c driving at 30mph without heaters. As soon as heaters go on it will start dropping. The DSG thermostat was a genuine part aswell from TPS
Might be an over sensitive gauge. Can you use VCDS to check the actual temp and compare with gauge. Mine drops slightly in really cold weather but normally dont notice when heaters are on. On mine which is diesel I think there is an auxiliary heater for cabin. Wonder if its a problem with it somehow if you have one.
Alasdair
If it's still overcooling after all of that I'd question if the work was actually done by the mechanic..did he give you the old parts.
  • 6 months later...
Iv had heater matrix replaced and another genuine thermostat fitted and issue still there. Anyone have any ideas what else it could be?
Recently Browsing 1
