2003 Fabia Front N/S Fog Lamp Unit
Hi experts,
I've searched the site, eBay, google etc. without a useful result. Can anybody point me at a cheap supplier of the subject item? The glass is cracked & I believe I need to replace the whole unit.
I had the same problem a year or two ago with a Fiat Punto & found the replacement part was quite easy to fit myself, so I'm trying to save a few quid by doing the same on the Fabia.
Thanks,
Ray.
Straight forward swap - Only place I know that sell them is Skoda...
There is a current thread on here regarding them - try searching again
Ain't worth replacing, mine are always cracking or being smashed by stone chippings, covered up in loads of clear tape. Result-Lights work fine and are protected!
You make an excellent point - they are almost designed to be smashed in normal usage. My missis, however, doesn't like driving around with them like that.
I wondered if it was a common part that might be cheaper on another make or model. 30 years ago, when I had a Triumph Spitfire, a lot of the bits were the same as on other vehicles & much cheaper to buy if you knew the part numbers for the other makes.
I did. No joy. Stabbing pains in the wallet tell me that I'll end up going to a Skoda dealer & paying mucho pounds.
