Retrofit Parking unit 76
Hi I installed the front parking sensors and changed the unit control module from 4k to 8k one.
The car is 2021-2022.
With rear view camera+automatic gearbox+ electrical brake+ autohold + start/stop + combustion engine.
Before the car was equipped with just rear parking sensors and a rear view camera.
I am getting error missing databus (u112100) in module 19 and module 76.
In the infotainment things seem to work but sensors seem to be less reactive. And no progressive color from orange color to red when approaching some thing. Line color dont change it begins red end red. The bip is ok.
I think something wrong with long coding. Could somebody send me scan of his car equipped with front and rear sensors.
Correct Date Set on the unit 76?
Where to check !
Where to check !
Attached scan module if it can helps
UNIT 76.txt
Was it a new control unit? Or used? If so, from which car
New control unit from AliExpress
The unit is config Audi what i See
Do you have long coding for Octavia A8 2021-2022
Coding won't help you much if the data set is incorrect. Additionally, the adjustments must also be made.
How to correct the dataset and do adjustments?
Could I run the car like this
