Gearbox error codes advice
Hi Folks, I need some advice regarding a series of gearbox error codes on my 16' Superb 2.0tdi DSG (6 speed) detected during a scan with OBDeleven.
I have attached a screenshot of the error codes.
The car has been running fine and the gearbox behaving as it should but this is the 2nd time I have had these codes present after clearing the same fault codes a few weeks back.
Should I be concerned? Thank you
Did you run the scan whilst driving the car?
I only ask, as I got very similar results a few days ago, whilst scanning and on the move, however the car's been driving fine.
I had scanned the car a few times before whilst stationary/engine off and not had these faults before.
However...in between the no-fault and fault-riddled scans, I did a gearbox adaptations reset (which has made the car drive better), so hopefully haven't unearthed any underlying problems.
I'm away for a few days but will rescan it without driving.
Hope that helps.
Thanks for your reply. I didn't scan whilst driving but the engine was running/car stationary whilst scanning. Would this have caused it maybe?
Edited by johnthomas99
Spelling
Hi There,
Thanks for your reply too.
I really don’t know, so will scan mine without it running when I’m back from my travels and let you know.
I did just google search it though, and found this post on the OBDEleven forum:
https://forum.obdeleven.com/thread/1846/stuck-gear-message-driving-scan
Hopefully someone else with more knowledge will chime in the meantime 🙂
Edited by CubbyQ
That's interesting. Thank you. Let me know After you get round to scanning yours again?
Will do buddy!
Scanned this morning with ignition on and engine off.
No errors at all, woo-hoo!
That's good news. Thanks for sharing.
I've just done a 144 mile journey and have obdeleven scanned with ignition on / engine off. No gearbox error codes, so that confirms that the above error codes will be present if the engine is running. Many thanks for your help.
