Remove roof aerial and A-pillar trim
My daughter wants to get the roof wrapped because of lacquer peel.
We want to remove the roof aerial and the black trims on the outside of the A-pillars. Has anyone removed these?
Are these parts easy to remove?
Remove 2 poppers in the roof lining to get to the aerial connector to be pulled out and it is a 21mm nut inside the roof lining to loosen the aerial.
The A-pillar trim did not come off, but that is just fitted with 4 Torx screws.
